Shower Drain Receiving Pipe
Ben67
Arlington, WA
I just found out that the second floor shower drain is leaking. The good thing is that the ceiling has been removed for repair so I have complete access to the piping.
From what I can see the receiving part of the pipe is bad. I tried to remove with with special tool but it does not turn. Looking from up there is a lot of white stuff between the drain and the receiving pipe which l think is silicon.
How can I remove and replace the receiving pipe in addition to putting a new shower drain while I am doing it. Thanks for the help
John Gayewski
Iowa
Loosen the black nut on the bottom side. That's what it's holding the drain to the tub.
Ben67
Arlington, WA
Thanks for the reply.
That is what I have been trying to undo, but it seems that the builder has used some sort of silicon glue which makes it really hard to unscrew.
I was thinking of using a hair dryer to heat the joint and then try to unscrew it. I am going in the right direction or am I wasting my time?
Is there any way to unscrew a joint like this? Or should I just cut it off and add a new section with threads?
I
John Gayewski
Iowa
As fast as I know the UPC hasn't made pro press legal for underground. I know the companies that make the fittings are saying they can be underground. Not sure about IPC
