Shower Drain Project
afonje
NJ
Background: My main goal is to place tile in the shower area as shown in the image below. The reason for this is because the pre-made plastic platform did not fit with my drain hole so the only option is to lay everything with tile which I do not mind doing.
The Problem: I need your help with finding the best resolution at solving the problem while installing the drain pan. The pan I have is shown in the images below. The problem is that the groove (marked with a white arrow) does not allow me to push the pan over the pipe so that it becomes perfectly flush with the floor. I was thinking of shaving off that groove so that I can fit it over and make it flush. Next, I need a way to watertight seal the outside of the pipe (once the pan is over) so that water is strictly directed down to the drain. Please make any suggestions for the best tools, gaskets, sealants, and the best way to take off that groove on the pan. My budget for the listed essentials is around $200.
Ryan Symons
Dihydrogen monoxide specialist
What you have there is not a shower pan. It is the lower portion of a Schluter drain. It is designed to be used specifically with the Schluter pan, kerdi membrane, ect. They make a whole shower system. It is pricey but very good. You need to do more research before you begin this project. You are headed for big problems.
