Jimbo
In your last picture, 90 #1 is copper, 90 #2 is part of the P-trap and appears to be ABS. #3 appears to be an 1/8 or 1/16 bend to line up the drain.
In the previous picture, I believe the line labeled #1 is a sweat joint where the copper female adapter ( the piece just to the right of that line) is joined to the copper 90. I would not cut any copper.
The piece labeled 90 #2 in your final diagram, if that is plastic as it appears, just cut right thru it. The remaining piece on the left will unscrew from the copper, and all the stuff on the right just goes away. Get a handful of assorted ABS traps and bends and maybe a foot of pipe, and start building.
The first piece will be a new male adapter to connect to the copper, and the final pieces will be chosen to line up with the tile drain flange you need.
