KristenJensen
Hello friends,
I have a cement slab home from the 1950’s in El Paso, Texas. I tore out the entire shower for a redo, and decided to center the drain while I was at it. My plan is to cut this pipe near the bottom, attach a 90, then a short straight piece horizontally, then another sweeping 90 with another short piece going vertical to where the drain will attach. I would use a primer and PVC glue for the attachments (after dry fitting.)
Does these sound like the right steps? And do I need a slight slope on the horizontal piece for proper drainage?
Finally, on the height of the drain, I assume the 4 plastic nubs (that the 4 screws turn into) will be under the cement when I pour so that the flat part “rests” on top of the concrete I pour? I will be pouring a pre-slope.
Bonus Question: What YouTubers have good plumbing channels? I like the following, even though they aren’t plumbers by trade they dabble in it. TileMasterGA, SalDiblasi, StarrTile (I know the last guy is controversial)
Thanks everyone
Thanks everyone
