Shower cartridge
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jjyoung500, Jan 13, 2018.
  1. jjyoung500
    jjyoung500 New Member
    Jan 13, 2018
    Michigan
    Long story short....plumber said I needed new shower cartridge because i had shut my water off in an unrelated incident, turned it back on and then had no pressure and no hot water at only one shower (upstairs). I assume he thinks there is some debris in the cartridge. Everything else was good. Did pull some debris out of a bathroom faucet. So I ordered a cartridge that appears correct and I still do not have good water pressure. I do have good hot water there, but the pressure is awful. Any tricks to reinserting a cartridge and having better success?
  2. plumber69
    plumber69 In the Trades
    Jun 20, 2014
    Prince Rupert, British Columbia
    Pull off shower head. Clean.... your plumber was wrong
Similar Threads: Shower cartridge
Plumbing Forum, Professional & DIY Advice Tuscany single handle shower cartridge (type F) leaks when trying to reuse May 27, 2018
Plumbing Forum, Professional & DIY Advice How do I remove this handle to change shower valve cartridge? Apr 19, 2018
Plumbing Forum, Professional & DIY Advice Delta 600 Shower cartridge help Mar 24, 2018
Plumbing Forum, Professional & DIY Advice Limited hot water at other fixtures in house after installing new shower valve(no cartridge yet). Feb 27, 2018
Plumbing Forum, Professional & DIY Advice KO-1 Cartridge for Kohler Coralais Shower Faucet Replacement Dec 27, 2017
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
