NoviceLurker
The new Kohler cast iron shower base came in and the drain location is in a different location than the tub. It would seem to be an odd angle to connect the new shower drain to. Also it's a cast iron pipe going to the stack that collects a lot of hair regardless of strainer used. I'd like to bypass it. Replacing it isn't an option as it would be impossible without tearing up the whole floor when isn't happening. I have a sink line right outside the bathroom that I can tie into. I will be redoing the kitchen soon and will be replacing everything to the right of it with 2". To the left is the washer that os connected to 2" that goes to the line that exits out to the street. I'd replace everything to the shower drain with 2". The one issue is the 4x4 stud that blocks the way.
The bottom of the stud is parallel to the bottom of the current 1 1/2" line coming off of the sink. So, the new pipe would have to go under and then up to the height of the 1 1/2". Is this ok to do? If so, how should I tackle it? I would use the cast iron if it would work, but it's 100 years old and collects easily.
Attached is a photo of it all.
