Should my furnace be pre-heating my hot water?
ChimeraKC
Rockland Maine
Two questions actually - A few years ago when we bought our home, we got a new Bradford White Aerotherm water heater that has a heat pump. Told its very efficient.
What they did though was have the incoming water come through our oil furnace and radiator system - and the furnace keeps the water in there heated pretty high - it comes on now and then for a couple minutes. 24/7. But we turn it off in the summer - we are in Maine - so this is really a winter concern.
We were told that it was set up this way so that if there was alot of hot water demand, the heat pump would have water already heated from the furnace. Two things about this - its just two of us, rarely if ever is there a lot of hot water demand - its a pretty big tank too- but more important why would I want my less efficient oil furnace heating my hot water that goes into the way more efficient brand new hot water heater?
Second question - in the winter, when the heat is coming on more, is it more efficient to have the furnace coming on and off to keep the water that will circulate to the radiators warmer?, or just let the system turn on and off from the thermostat which means the water is being heated from a cooler temperature?
I am also going to speak to the heat pump company. Thanks for any help.
Fitter30
Peace valley missouri
Bradford white wh is where its located is the space heated? If the space gets cold the heater will run on the electric heating elements and not the heat pump driving the operating cost up. Cast iron boilers like to be kept warm with return water (water coming back to the boiler) 135° or warmer. Outdoor reset control can be added to boiler it will vary water temp on outside temperature. At 0° house might need 180° at 50° need 155° and shuts the boiler off at 65° - 70°. Boiler in the basement any heat when system isn't calling for the boiler isn't wasted going up into the house. Taco and others make E series pumps that are more efficient using a ecm motor. If and when you might need a pump.
WorthFlorida
The wife is still training me.
Solutions
Orlando, Florida
Well established contractors in a given area usually knows what works best for their climate and install things for better performance and comfort.
It seem strange to me but I'm no plumber. I think what happened is you probably have very cold inlet water temperatures. Right now I'm in West Dover, VT and the well water is in the 40º's. Heat pump alone probably would not be able to meet hot water demands and it needs to be set for the electric elements to kick on when the demand exceeds the hot water demand (Hybrid mode). The contractor who set the system up and maybe from other customers receiving complaints during the winter months was a lack of hot water because many program the water heater to HP only. It also might be the cost of electric might exceed the cost of your furnace fuel to heat the water during winter use. Contractors do not like complaint calls under warranty because of lost of revenue and the system is working as designed especially during extreme cold. So things get tweaked to minimize these type of calls.
If the WH HP is in an unheated space like a basement, the contractor may have felt the ambient air is too cold. I could not find the specification for ambient air temperature for your model.
It's almost a mute point. To keep the home warm by heating water takes the same energy. Heating the water from a colder temperature or keep the water warm before heating up to temperature for home heating, the difference will be the standby lost and the efficiency of the furnace. In standby with warmer water the heat is lost into the home anyway. For me the bottom line is comfort, one way or the other. It may take longer to bring the cold water temperature up to heat the home therefore the temperature swings might be noticable.
If the system is working fine for you and the cost is not of concern, leave it as is. Normally water heaters are separate from your home heating system. Is there any way the bypass (installed valves) the furnace to bring the cold inlet water directly to the WH without doing plumbing changes? Hopefully the contractor did install valves should the furnace ever needed service or replacement, you would still have running hot water. If yes then give it a try with the WH in Hybrid mode.
blueskyme
Maine
It sounds like you had a smart installer. I'm not a plumber, but as a fellow Mainer, the setup you described is my exact preference.
I have found that heat pump water heaters installed in Maine have the tendency to make the rooms they are close to uncomfortably cold in late fall, winter, and early spring.
One of my rental properties has a direct thankless water heater coil buit into the boiler. The Low set point has been turned completely off. Domestic cold water enters the coil, it is pre heated if the boiler is running, it then continues on to an electric tank. This provides a few benefits. We have very cold inlet water during the winter and the boiler takes off the edge. During the summer, the boiler will not turn on.
During the winter, the heat pump water heater at my parent's home is not adequate while in heat pump mode. Switching to hybrid is sufficient, however this lowers efficiency. To resolve this, whenever the down stairs zone is turned on, a valve for an indirect water heater also opens. This indirect water heater will pre heat water to increase capacity. This is convenient because again it's an automatic process when the house gets cold.
In my personal home I'll be adopting the same set up with an indirect tank soon. I live in a raised ranch, after we had a heat pump water heater installed, the boiler struggles to keep the downstairs above 60f.
Fitter30
A tankless coil in a cast boiler has a low setting ( 135°) as to not cold shock the boiler. Cast boilers do not handle wide temperature swings very well they tend to crack a section then their normally replaced not repaired. The volume of water for copper 1/2" m 20' is .26 gallon , 3/4" m 20' is .54 gallon. Not a lot of volume to make a difference. Your house what type of heat emitters, pipe size, length and water temp for l level.
