Should I reset a new toilet?
InclinedPlane42
Kansas
I recently installed a new toiilet and followed the instructions included with it, using the provided wax ring. After reading this and other forums I realize that I should have used a thicker ring since flange top was flush (or even slightly below) the tile. There doesn't seem to be any leaks (or smells) and I haven't caulked it yet so I think I would notice. Should I pull and reset the toilet with a more appropriate ring or should I keep it as it is since there seems to be no leak?
John Gayewski
Iowa
Did you feel it squish the wax as you set it?
Peterson
Active Member
PA
I'd keep it uncaulked for a while just to make sure that there are no leaks. If it doesn't leak and there is no sewer smell, then you did it right! Good job!
