GravyEatingDog
If I upgrade from a 9X48 resin tank to a 10X54 to increase resin capacity to 1.5 cubic ft, can my existing Fleck 5600 handle it? Seems like a reasonable upgrade for the cost of a larger tank and additional resin.
4 people
21.3 gpg
Would appreciate recommendations on settings for 1.5 ft resin.
Also, I would consider a 2.0 cu ft system, but believe a control valve to handle this would require 1" water line and I'm currently 3/4" out of the pressure tank.
Thanks
Current system is 20 yr old, Fleck 5600, 9X48 tank w/ 1.05" distributor tube - it has been bypassed for the past 7 years because the tap water tasted salty. I recently rebuilt the Fleck control valve and am in the process of putting it back into service.
2016 water test results (Virginia Tech Extension service):
364.8 mg/L hardness
0.007 mg/L Fe
10.5 mg/L Sulfate
8.56 mg/L Sodium
Mn, Ar & Flouride - not detected
Total dissolved solids: 476 mg/L
Nitrate-N 4.028 mg/L
pH 7.3
4 people
21.3 gpg
Thanks
364.8 mg/L hardness
0.007 mg/L Fe
10.5 mg/L Sulfate
8.56 mg/L Sodium
pH 7.3
