CountryBumkin
Active Member
I am doing some plumbing rework on my Kitchen sink because I replaced the shallow double bowl sink with a deep single bowl and now the disposer outlet is lower than the p-trap connection.
Since my plumbing comes out of the slab, I can cut down the existing 3" pipe and install a new sani-tee lower down. That solves the disposal drain height issue.
But I'm wondering about venting the new sink drain. This is an island Sink so the existing vent is in the wall about 6ft from the sink itself.
Since I switched from a double bowl sink to a single, I'm wondering if I should add (or need) an Air Admittance valve. In a double bowl setup does the adjacent bowl act as a vent for the bowl that is draining?
If I need an AAV, I could use the "unused" 1-1/2 connection on the left side of the sani-tee to add the AAV. If this is a good idea, I would add enough pipe to get the AAV to the highest possible point under the sink (but it would still below countertop).
I don't have any drainage problems now - I just want it to be correct.
