wlpitcher
Could a 14" Toto Uni-fit adapter be cut, shortened and welded back together?
We're thinking of a Toto Guinevere toilet. I thought our rough-in was centered between the hold down bolts but the plumber said it's at the rear bolt, which makes it 13" from the wall. Can't actually locate it until the existing toilet, in there since 1940, is removed. We're tight between the front of the toilet and the shower door swing so can't afford wasted space behind the toilet. Could the 14" Uni-fit adapter be modified to fit?
Or could the toilet be set about 1/2" off center on the trap seal, which would still give 1/8" or so clearance between the rear of the toilet and the wall? How much "wiggle room" is there in the setting?
Or does Toto make a compact elongated toilet, shorter front to back, which would allow us to put this toilet in without all the maneuverings?
