Hi,
I'm having the same problem others have had with short cycling. Based on what I learned here, it seemed like bad a check valve. I pulled the check valve and it was indeed bad — I could blow through it both directions. I put in another check valve, drained the (full) water tank, put in 28 psi, and powered everything back on. I can isolate the house aft of the tank, and it still short cycles every 30 minutes or so. Now, there's a much longer delay before the pump runs after water use/flushing and instead of running for 8 or 10 seconds, it runs longer, like a minute to get back up to pressure. For some reason it also runs quieter. The check valve I used was one that a buddy had in his garage. It was still in the box and I blew in it and could only blow in one direction. So my question is this. Do you think I installed a second bad check valve, or is it more likely something else? If it's something else, can you give me some diagnostic steps? I'm pretty new to well water but have access to most tools and am determined to find a DIY fix.
