John Q Florida
Although the sink drains ok, there are moments where running the garbage disposal causes at least a little noise in the other drain, sometimes a little gurgling, sometiems splashing, and on special occasions, the fun part, squirting water 2 feet up in the air.
It's a new house to me, and it's more or less always happened. I've found some good suggestions on plunging and there is an access point to run a snake down too, which is what I have to look forward to this evening.
(As a sidenote, running some dishwasher cleaner was apparently the last straw for my garbage disposal, which is now leaking from the holes on its bottom; so it's while I'm down there replacing that, I'll look more closely at the plumbing in general too.)
Independently of my plunging and snaking though, I had questions about the design. To my amateur eye, it seems odd, so I thought I would ask. Pictures (this is an island kitchen, btw) here: https://1drv.ms/f/s!Anl-vA0RiSI_g6pD6EacZhEQBhVt5Q
Also, when I look carefully at the pipe in person, it really looks like the line from the garbage disposal to the junction is going uphill (I realize the pictures don't look that way, I must not have had the camera perfectly level.) I'll check with an actual Level when I get home too.
Thanks in advance.
Thanks in advance.
