Sharkbite - What do the plumbers think?
sapet
Canada
I have been in the industry for roughly 30 years, perhaps I am old and tired, and need to be sent in back of the barn like old yeller.
Here goes.
Pex B roughed house, into the finishing now ,what do the guys in the field think if I would say, I was almost tempted to put 1/2 X 3/8 sharkbite finishing valves for the vanity install, toilette install, kitchen sink install.
On record, I didn't. I crimped but, had to drive back to my shop, because I left without the crimper
So in short, be brutally honest, should I be declassified as a plumber with the thought even crossing my mind?
Most would say yes :cool:
You are in Canada and run PEX B? Amazing. Or is everything buried 10 feet down? What do you do for pipe insulation?
I don't see any problem with a Shark outside of walls (yes, I'm aware Sharks are allowed behind walls). If it leaks, the leak will be pretty obvious.
What I HATE is PEX sticking out of walls. I would use copper stub outs - you can still stick a Shark valve on copper.
John
I'm noy a plumber but use PEX B and copper stub outs and have no negative thoughts about a Sharbite stop slid on the copper. Under sinks where the PEX is through the floor I just crimp a valve on.
