Sharkbite to water heater
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by K2, Jul 16, 2008.
  1. K2
    K2 Member
    Jul 7, 2008
    Some computer junk...
    Delridge Valley
    Of course...and so does everyone that comes to this site looking for help, to do it themselves. Isn't that the purpose?
    You're jealous...i can tell. A mess?...well angels to some, devils to others...i've seen some professional plumbing work that I think is messy...
    It's not 1/2" wafer board, it's 3/4 tongue and groove OSB sealed with water proof sealant on all edges and face, counter sunk into pressure treated 2x6.
    Copper for looks? that's so 1985...and who cares what my mechanical room looks like?! I'm not shooting for the cover of Vanity Fair, or plumbers weekly.
    I have 2 relief valves per the inspectors cue, since there is no drain in site there is a 150psi valve attached to the tank, and a 120psi valve above grade for gravity drain...
    The expansion tank is sitting on a 4" piece of ABS (updated after this photo) the straps are there for 'looks'.
    I'd never put a sharkbite fitting behind a wall, the purpose of my home run is to avoid having fittings behind walls.
    I'm glad at a minimum i've given you some fodder for your next "what not to do" thread...I'm pretty happy with it, and it works.
    GO SOX.
  2. hj
    hj Master Plumber
    O rings
    If the Sharkbite "O" rings are going to fail in a few years, what does that say about the ProPress system which also uses "O" rings, but are not removable like the Sharkbites?
  3. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    We will open that can o worms when the time comes. :D
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Well Google Boy here is one important find that you missed.
    Take a good look at page 2 at this link!
    Click here to see UPC, IPC, & CSA Approval of Sharkbites Including Concealed & Underground Locations
    Push fit fittings that have a quick assembly push fit mechanism that can
    be used with PEX, Copper or CPVC tubing. Fittings for use in domestic
    and commercial application for both potable water distribution systems
    and hydronic heating systems. Push fit fittings can be utilized in
    underground applications and as manufactured joints without access
    panels. To be installed in accordance with the manufacturer's​
    instructions and the latest edition of the Uniform Plumbing Code.
  5. MikeW888
    MikeW888 New Member
    Sep 9, 2008
    Sorry to quote but I had a good laugh from this.
  6. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    Coulda fooled me:
    I gave up offering DIY info over comments like this.
    Do people really think plumbers are just lurking online waiting to put themselves out of work?
    As for the quality of the workmanship on your job, you have no idea just how gawdy it looks to someone that does it for a living, sorry, but that isn't quality workmanship.
    For starters, most states won't allow you to use plastic pipe within a certain distance from any water heating fixture..the list goes on and on.
    You happen to live in a state that allows DIY plumbing, yet I think we can agree you aren't pulling permits.
    I feel the urge to hop the soapbox, but I won't waste my time.
    What I will say...IF you're so confident in the work, pull permits and get it inspected.
  7. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    I say the exact same thing, over and over and over again.
    I think you'd like NhMasters thoughts on code authorities and big business.
  8. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    When I see crap like that I want to walk out.
    When someone is so willing to avoid having it done right that they resort to something that pathetic, I feel like an elevator in an outhouse when I get called.
  9. K2
    K2 Member
    Jul 7, 2008
    Delridge Valley
    But that's the catch 22 here, i don't think everyone wants to do things the way I did sure they want to do it 'right' (pulled permits and all), but we don't all have the money or schedules to get a plumber in...
    we look to people like you to really help us out...but we don't speak the language and we don't have a secret decoder ring so we ask questions and get abrupt responses or the ubiquitous "call a pro"...
    i get a hairbrained idea that i can plumb my whole house in pex (not 'plastic') and I tried to follow every code i read and every manufacturers recommended installation instructions...
    So please get on your soapbox and tell me what's wrong, because I don't know! maybe if i did i could take your challenge and get my inspection....that's why i'm here to learn from the bestest...
    ...i'm just a crazy kid in this mixed up world, who would be willing to bet copper got the same bad wrap as pex did 20 years ago, and I'm sure it can't be any worse then the galvanized junk i pulled out of my house all that corrosive pipe lining was going into my drinking water.
  10. K2
    K2 Member
    Jul 7, 2008
    Delridge Valley
    i laughed too, my only regret was not buying stock in CashAcme before I started this project.
  11. Redwood
    Dec 15, 2007
    Service Plumber
  12. Wrex
    Wrex Member
    Mar 19, 2008
    New Jersey
    No I knew that they were approved for concealed locations I mean't that I didn't like the idea.
    A fitting leaking behind drywall silently creating mold!
    As for failure I'm talking 10 to 20 years will be the true test not a few.
    It's no big deal if the fittings are accessable in a basement or crawl space but behind the wall is another story.
  13. Redwood
    Dec 15, 2007
    Service Plumber
    I guess that we are really in trouble then, because, o-rings have been used quite extensively for sealing purposes in plumbing for many years now...
    The failures should be coming in any day now...
  14. Cookie
    Cookie .
    Oct 7, 2005
    Home
    I would imagine alot of the codes are for your safety, I would ask the question, " can I afford not to have it inspected?"
    "It don't mean a thing, (If it aint got that swing), “du-wah-du-wah-du-wah"
  15. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    This isn't an 80 yr old retiree on a fixed income with a leaking water pipe.
    It's a luxury item, furthermore a gas fixture...no permits pulled.
  16. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I don't think I could add anything to the thread that I have not said before. Not pulling permits and inspections is a crime. In N.H. it's a felony, in other states it's a misedmeanor. And now that the pictures and facts are posted all over the internet I think if it was me I might be inclined to back track a bit and take care of these pesky issues before them come back to haunt you. I understand everyones desire to save a buck or two. We all want to get the best deal for our money, plumbers included. But there is a cost versus problems ratio that can not be ignored or denied. If for no other reason than peace of mind I would have it looked at. I still say that gas pipe is way too close to the vent. It's the safety of your family we're dealing with here. As for the sharkbites, that's your decision. It will probably work, but don't go looking for plumbers to give it a blessing.
  17. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    I think the sharkbite does have its place. I specifically use them when installating water conditioning equipment in a home that has CPVC. It makes a great transition from CPVC to copper and then I use my propress. A solvent weld should cure for 24 hrs. (at least several hours anyhow) before putting back in service and that just isn't practical. As far as the o-rings, I don't have a problem with worrying about those since the technology has been around for 30 years.
  18. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    I assume your a plumber.
    Think of how often you replace O-ring seals in faucets showers and other fixtures.
    Then imagine if those O-rings were concealed behind walls, ceilings having to replace them as often.
  19. 99k
    Aug 16, 2008
    I am a plumber and do just conditioning equipment which is out in the open. You must not get in the trap of comparing the two (fixtures and sharkbites)as one of the same, because the o-ring in the sharkbite is static (it never moves) and none of the parts move against it.
    An o-ring is a very reliable and robust seal. If you don't trust an o-ring, would you also not trust a PEX fitting behind the wall?
    I know a plumber that will do a whole house with a pro-press ... I never had a joint leak after learning how to prep the joint. We had one joint leak 2x because it had scale and pitting on the existing pipe ... Viega said in the case of an old pipe, first use steel whole to remove the scale (no problems since).
  20. Redwood
    Dec 15, 2007
    Service Plumber
    I too agree that an O-Ring in a static application has a long life.
Similar Threads: Sharkbite water
Plumbing Forum, Professional & DIY Advice Installing Water Line for Humidifier - Not Sure if I Should Attempt Sweating or Use a Sharkbite Feb 13, 2021
Plumbing Forum, Professional & DIY Advice Sharkbite Water Hammer Arrestors Jun 28, 2009
Plumbing Forum, Professional & DIY Advice How to take this Sharkbite comp fitting out May 10, 2021
Plumbing Forum, Professional & DIY Advice Kitec PEX-Al-PEX and Sharkbites Mar 26, 2021
Plumbing Forum, Professional & DIY Advice Can I use a Sharkbite connector on PEX-A? Mar 14, 2021
