Kulig
Hello guys. situation looks like this:
house is divided into two with separate crawl space access
1st house got pressure tank with regular switch at very high pressure 88psi ( no constant pressure switch) and no check valve that is good
2nd house got pressure tank too, no check valve, no pressure switch and various pressure at gauge between 50 to 65
and this tank is so rusted that not working at all. Need to be replaced.
2nd house owner got issues with cold water at sinks very low pressure, when I turn off supply to water heater there is almost no cold water pressure at sinks and showers, but still got high pressure at sillcock or any drain hose bibb
in my opinion water heater there works as pressure tank
Low water demand- low pressure
do I need to instal new pressure tank with check valve and ball valve to tank tee and another ball valve after tank tee (to be able to drain the system) that will help with low water pressure at sinks? I do not want to do anything at 1s house
any ideas?
any ideas?
