Alfred in El Paso
Greetings from El Paso. I have had a shallow well setup strictly for watering my yard and trees on a large lot in Socorro Texas for years in the valley. Several months ago started having trouble and burned up a good sears convertible jet pump. Water table has dropped to 23 - 24'. I blew mud out of the well with compressor but the level is right at 24' at best. The well depth is 38' and so there is maybe 14' of water. The other problem is the well is 2 1/2" casing evidently not used in years.
Was suggested a deep well jet pump with packer but I can only find it at 2" (in fact I ordered a Dayton ejector pkg 2" single pipe from Grainger which I will return). I thought I could put 2" pvc in the 2 1/2" casing but there is not enough room for connector joints.
Can't find any submersible pumps that will fit in the 2 1/2" casing nor packer assembly for 2 1/2" either. Might it be possible to run a two pipe system 1 1/4" and 3/4" with adapter for the casing if such a casing adapter exists? Any other ideas or referral to well supplier is greatly appreciated.
