islander1061
Long time lurker, first time posting...
I've got a shallow well on the beach that goes down about 12 feet, consistent water level around 3 feet. Currently I have a check valve and sandpoint in the well, with 30ft of line with about a 20 foot rise going to a 1/2 hp Meyers jet pump. I had to run a new line recently and unfortunately there is no way to run it without having a high point in the line. All last season the pump was kicking on/off multiple times before shutting off and holding pressure. Assuming the high point is holding some bubbles, leaching some air into the pump every time it kicks on.
My question is, can I remove a jet pump and just run a submersible into the shallow well? My thoughts are, this would eliminate the need for priming at the beginning of the season, as well as fix the issue of having a high point in the line, given the water would be being pushed rather than pulled. I'm sure I am over simplifying this, but I have searched everywhere thinking for sure there has been a discussion about this... but I haven't found it!
Any help is greatly appreciated, Thanks in advance!
-m
-m
