zeetwoeight
Good day all,
I purchased a country cabin with a shallow well pump. I am a complete newbie when it comes to pumps so I have a question on the way it was wired up. Please see attached diagram (NOTE: I can't recall if that fuse was a 25A or 30A but it was larger than 20A - which I thought was wrong since the 12/2 is for 20A correct?). Couple of questions:
1. I'm assuming the switch/fuse panel is there to server two purposes: first a way to easily turn off the pump rather than just unplugging it ; second to handle the initial startup load and avoid tripping the 15 breaker? Would that be the case?
2. If I wanted to replace the switch/fuse panel could I use an outlet controlled by a single pole switch (both 20A rated) fed directly from a 20A breaker in the main panel? This still allows me to turn off the pump easily.
3. If my #1 point above is not the case, can I just use an outlet controlled by a single pole switch (both 15A rated) fed directly from a 15A breaker in the main panel?
Thanks for an input/info. Cheers.
