So I’m replacing the jet pump that services our home with water from a shallow dug well. I pulled everything off the main line and left it open to air and the water level never went away.
So I assume that means I have a foot valve, right?
The previous owner also had a check valve immediately before the pump inlet. Is that recommended or needed?
Assuming there is a foot valve and it’s working then it’s probably a bad thing to have another check valve or what purpose does it serve? Just incase the foot valve fails (unknown age)?
Should I replace it or remove the check valve all together?
