Shawn Prathger
I live in a rural area and have been on a driven, sand-point well for years. Recently, I noticed the amount of water available was gradually getting less and less. I decided it was the point clogging up. A few days ago, the pump motor burned up, I assume from the same issue.
Since I had the well opened up to replace the pump, I took the opportunity to drop a gallon of muriatic acid down the shaft to help clear the point. (It was recommended to me at the hardware store)
Now, with the new pump, I am drawing up so much sand that it continually clogs the pipes, the valves, everything. I take it apart, clean it up and reinstall, it works for a few minutes, but then clogs again.
Also, when replacing the pump, I added a large pressure tank. Before this, I had always used the smaller tanks that come attached to the pump (at Menard's... Simer)
Did the acid eat through the screen? Will the sand eventually go away if I keep cleaning it out? The well is in my basement, so pulling it up is going to be a major operation.
Any thoughts? Guidance?
