Steven J Jensen
I have a cabin that is built on a slab, in Northern Wisconsin. Coming out from the cabin the sewer line is only 6" beneath the ground. It runs to a holding tank about 40 ' away. The depth of the line at the tank is somewhere around 24" to 36" underneath the ground. This is a holding tank not a septic tank. What are my options so my sewer line doesn't freeze? This cabin hasn't been used during the winter before but I would like to start using it.
Is there something like a lift pump if I dig the sewer line deeper and put some sort of pump on the end to lift the sewage into the tank?
Or could I wrap the shallow end in heat tape and insulate the entire run?
I am open to any options and before calling a professional I am seeking advice to see if it is something I can do myself.
Thank You for an info you can provide!
