Shallow irrigation well low pressure?
Linescreamer
Fl
I have a pump start relay to turn my jet pump on. I am concerned about burning up the pump if my 2 20' well points run out of water. Do I need both a low pressure cut off and a pressure tank? I also am not at this property for extended periods and will not be available to reset manually. Thanks
I had a suspicion that would be the answer. Do I need a pressure tank or just the CS Monitor?
