robert ramsperger
Good Point...
New member here looking for some advice on a sewer smell problem in downstairs shower. I have searched
the site for a solution but have not come up with anything that helps. Great site though, lots of useful knowledge.
We had a plumber install a shower drain next to toilet drain under slab on first floor. I built a bathroom with a custom shower over that work and began to use it recently and discovered a foul smell in the air coming from the shower drain. The smell goes away when shower is used however when the other connecting drains are used the smell comes back. I took the toilet off to watch the flow and the other drains go back to the shower trap first then eventually find their way back out the main. Every thing drains well and the trap stays full but
it always seems to be fouled with sewer water until the shower is used. One other thing, when I pulled the toilet there is standing water in the main under the toilet. My first thoughts are to run a high pressure clean out
down the main from the toilet flange because the main might be partially blocked further down the line, hence the standing water. My other thoughts are to dig and I'm hoping to avoid that. Any comments welcome. thank you. Pictures attached.
