I was directed to this forum by some people on the plumbing forum. So here goes..... We're having a problem with intermittant sewer odor in our home. It usually happens after we've used large amounts of water, such as showering and laundry. It doesn't start right away, but several minutes after we've used the large amounts of water. (Maybe when the gas water heater kicks on?) The smell is in the basement, and when the furnace runs, it quickly spreads the odor all over the whole house!
We already have made sure that all traps in the house are full, run water in them all of the time, we checked out the basement floor drain, which can't be the issue, because it doesn't drain into the septic system. All sinks, toilets, showers are draining fine.
We just wanted to see if this is something that we can rectify ourselves before calling in a plumber. Our well pump was replaced about a year ago, maybe a year and a half. Also we got a new pressure tank. The odor just started several months ago. Seems to be worse when it's cold outside here in Michigan. Cold meaning in the 30's or less. I did notice one day, as I was getting some water from the faucet that looks like one of those old farm pump things, that comes up directly from the well, that the water smelled similar to our sewer odor in the house. But being windy, the smell wafted away before I could get a really good whiff of it.
By the process of elimination, we're next going to try finding all of the connections in the drain lines in the basement and use some plumber's putty around all of them. After that, I suppose we'll have to call someone to go up on the roof and either do a smoke test and/or run something down the vent stack to see if there's a partial blockage or something. We have no tall trees, so don't think leaves are down there, but could be a yellowjacket's nest, a bird, something......
So could this actually be a water issue, not a plumbing issue? I had our water heater set at 120 degrees, but recently turned it up to about 140, thinking that perhaps some bacteria are in the water heater. If this were a water issue, why would the basement smell?
Any help would be greatly appreciated. Thanks!
