Amber Follis
I live in Austin, TX. About 10 days ago I noticed a strong ammonia or sulfur type smell coming from my downstairs bathroom toilet and sink. It appears to only occur at night. I use this bathroom regularly and have 2 other bathrooms upstairs that are used a lot less often, sometimes not at all unless I have guest. Last Friday I had a plumber check the sewer drain, remove the toilet and he said all came out clear. That night I started smelling it again and noticed the toilet bowl was also very low on water. For whatever reason I took some water and filled the bowl up a little to see if it would go away and noticed the water level dropped back to what it was before adding additional water... I refuse to stay there and my dog doesn't even want to be inside the home. Any ideas? Is there a certain plumber who specializes in this sort of thing I need to call? The last company that came out were gas leak specialist and $650 later nothing found.
Sorry if this sounds confusing. I never thought I would be researching this subject Thank you!
