Apryl Brown
Need advice, broke nursing student with a semi handy man hubby.
We started smelling a bad sewer gas in my daughters closet. This closet was capped off 15 years ago and not ever used d/t expense of repair, we basically pulled everything out, capped it off and dry-walled it into a closet. Orig. it had its own water line/water heater that was under the kitchen sink (small bathroom), this was all disconnected, not used when we moved here 15 years ago.
We have a laundry room that recently started having some leaky pipes (or so we thought, turned out to be the washer). My hubby capped some pipes off in the laundry room (mainly the one to the watersoftener because we orig. thought it was the source of the pipes leaking in there when it turned out to be the washer). I suspect a dry line from him capping that off but why would it smell in my daughters room closet on the other side of the house when to my knowledge that plumbing was never connected and ran on separated pipes/water heater that hasn't been used in 15 years.
We have well water with city sewage.
It is my understanding the genius' that built the house laid the pipes in the concrete (going to my daughters room where sewer smell is). The rest of the house (which was an addition 15 years ago, has a craw space and normal pipes) so 1/2 house is slab with pipes under and the other 1/2 is crawspace if that makes sense.
The smell is horrid and I don't know if he will have to start tearing out drywall in that bathroom/closet to solve the problem. It just makes no sense we are just now getting this sewer smell when it's never been an issue in 15 years and the only "outside" factor is that we recently capped off pipes in the laundry room (has the crawspace) going to the water softener... HELP is appreciated!!!
