natureboy27
Need help in diagnosing a sewage pump issue.
My sewage pump have 3 floats (lower float switch, upper float switch, alarm float switch). All 3 of the float switches have been tested successfully. The pump will NOT turn on when only the upper float switch is in an up position. The pump will turn "on" when both of my lower and upper float switches are in an up position.
My problem is that the pump turn "off" when only the upper float switch is in a "down" position. The lower float switch is still in an "up" position. I know the pump suppose to turn off when both float switches need to be in a down position so that it could remove more wastewater out of the tank. Does anyone know what cause it to turn off when only 1 float switch (upper) is in a down position?
Thanks in advance.
Thanks in advance.
