rockosani
Hi... I purchased a Little Giant Sewage Ejector Simplex Package... and that was the easy part. I'm trying to add a full bath in a basement that is about 4' below grade but when I dug the hole for the container... about 27" down... I hit water. Now I have about 8" of water in the hole and it's all but impossible to get the container to sit properly since it now wants to float. I have lots of ideas... none seem very good and I was hoping you may have a suggestion for the do-it-yourselfer.
Can I drill a few holes in it to balance the pressure by letting the water table rise to an equal height in the tank? I'm not sure how that effects the effluent in the tank but would a back-flow valve work to let the water in and not the effluent out? I doubt that the water would be high enough to trigger the pump but I'm at a loss on what to do in the event we get some heavy rain, the table rises a little more and my poop pump is bobbing up & down in the hole with some pipes hanging out. Lastly, would it make sense to drop the tank in the hole, fill it with water, apply some concrete anchors to the floor and then pump it out?
If none of those ideas work I'm open to suggestions and know answering this stuff is probably not why you go to the office but anything would help. Thanks
