So I bought a new Zoeller sewage ejector pump that has a 2 inch output as well as a 2" Zoeller check valve. However the existing system was done using 1.5" pvc. I should have checked this before i bought the new pump.
So I am wondering, do I need to get a different pump?
Or can i put a 1.5" to 2" adaptor between the existing 1.5" ball valve and my new 2" check valve, then run 2" pvc to the new ejector pump?
I probably have 7 or 8 feet of lift required of this pump.
Also are there any possible issues with building codes with this setup (McHenry County, IL)?
Thanks for any help.
