Hi all,
Thank you for any input, and I apologize in advance for my plumbing ignorance.
I own a small animal hospital and am going through an addition/remodel. We just moved into the addition while the old building is being remodeled (old building is 10 years old, never had a plumbing issue).
In the past 2 months, we've had 3 backups of raw sewage into our new surgery suite. Upstream from the OR is a toilet, sink, and kennel drain; downstream, the 3" pipe ties into a 4" pipe via a Y joint.
First plumber blames tampon, second plumber blames an unidentified solid object, and 3rd plumber determines a back flow at the Y joint that goes upstream and downstream in the 4" pipe.
Contractor wants me to put in a toilet with a pump to pump sewage up and over a wall into the old building and avoid the new pipe all together.
I would like advice from someone that is not involved at all in the project. I have attached a very rudimentary drawing.
Thank you for any advice.
Erin
Erin
