Schibig87
Hello,
I am finally installing my Rheem Hybrid Water Heater and would like to confirm that I have the electrical connection process correct.
I was able to wire my HVAC and pass with your help and felt this unit will be similar. getting so close to final construction approval
It does appear to have a CTA module ? I was thrown off by the 2 smaller wires accompanying the 10 AWG and if I am reading the CTA instructions (picture) correctly, They get wired along with the main power connection. The ground is already set up this way from factory.
I will use a 30 AMP double pole breaker 10/2 wire from breaker to a 30 amp rated service disconnect, a 10/2 whip from disconnect to HW heater.
I plan to use a Wago 221-612 or 613 for 10-20 AWG for connection (if wing nuts are better I can use those instead)
I will wire the small CTA red with both 10 AWG reds, same for black with black. Add ground to the screw using a round terminal connecter.
I was surprised to open the box and find that the cold water inlet is close to the floor and hot outlet mid machine. I see they have since upgraded so that the water supply hook ups are on the top. That said, looks like I have a lot of pipe to run. Question is, which will be best type of pipe? PEX, Copper, PVC or a combo?
I have the heater sitting in a floor pan and will terminate condensation to outside via PVC pipe vs an evaporator since the unit is very close to an exterior wall.
If not too difficult ( I am familiar with the copper sweating process and PVC, expansion pex. not crimped ) I would like to do this plumbing myself. If too involved- I can call a plumber.
My main concern is the wiring.
Is there any issues/concerns with these tanks prior to my installing? If they are not great quality or have issues I would consider switching- I just have to meet energy code for occupancy.
As always I appreciate you all,
Patty
Patty
