Steve king
i am pouring a shower pan. Preslope, liner, and then sloped pan. I have plywood subfloor 3/4 inch and I put another 1/2 inch of plywood over it. I am confused about drain height. Using 3 piece drain with lock ring for liner.
I have seen different placement of the drain in diy videos. Some people put the bottom or flange of the drain flush with the subfloor. Others put the drain a half inch or so above the subfloor.
I decided to have a licensed plumber reset the drain. He says the flange should be flush on the floor. If I do that, and then lay the mud for the preslope, does the Mortor go right to the edge of the flange? It would be very thin there not eve 1/4 inch along the edge of the drain, more like 1/8 inch
I bought an Oates 3 PC drain and it seems to want to sit on top of the subfloor, since it does not have screw holes to mount to the subfloor. I showed the drain to my plumber and he said it would be flat on subfloor
I have seen some videos where they mud under the drain on the preslope, with the drain raised.
I would rather do what the plumber says and screw a drain flange to the subfloor. I am just concerned about how thin the mud will be at the slope
Sorry this is so long. Just want things done right and to last. Thanks for your advice
