CHOLLA BOB
1" Schedule 40 is in the 60 foot trench with a curve glued on one end and the opposite end is the straight end. I have a piece of aluminum electric fence wire pulled through this length. Should I now pull a stronger, new piece of 1/4" marine poly through with the fence wire, for the final pull of the three 10 gauge wires? Can I do this on my own, through the straight part to the final turn, pulling the poly with conduit lube? Or do I need a second person pushing the 10 ga into the conduit. I had no compressor to blow through a pull line so went with the fence wire which is hard to glue to the pipe. I will pull wire through final 5 foot verticals after I get past the 60 feet. Snowed in so this is getting interesting with the no water situation: winds blew and filled in all tracks then froze.
