SAS
I installed a 220 volt timer that controls my hot water heater. I tapped into the existing wiring, which did not have a neutral - just two hot wires and a ground. I would also like this timer to control the hot water recirculation pump; that requires a 110 volt circuit. Since there is no neutral, I would either have to 1) run a new cable with a single white wire, 2) use the existing ground as a neutral, or 3) replace the existing run from the timer to the panel with a cable with 3 wires plus a ground. Using the ground is the easiest, but I suspect it is a code violation. Running a separate cable for the neutral is not a big deal, but if I do that does the cable size have to match the existing cable?
