1hp above ground well pump for home. average depth for my area is 50/60'
I asked questions last May about sediment coming from well into house. we had well guys out and they did the turn on spigot for about 15 minutes and the bad sediment problem stopped until now. Now it is even worse, i have to empty out the Rosco filter once and sometimes twice a day. Our choices are a new well or adding a sleeve. well guy says casing could be cracked somewhere. Of course there is no guarantee it will work. he said the sleeve goes (inside) the well pipe.
My questions: regarding the sleeve, Do these sleeves go all the way down? I've read about casings that are only 5 feet and they cover a submersable pump,I havn't found any information for my situation. pump is above ground. could you give me an idea on how far they actually go? If they only go for example 5 feet and if there is a hole in casing farther down? do any of you have any luck with the sleeve idea? Have any thoughts?
and what i cant understand, if there is a hole in casing, how does the sediment issue slow down so much and we have clearer buckets and sandier buckets.
Same thought on a bad well, how would the sediment not always be an issue.
its my moms place, she is on a fixed income, I help fix what I can.
thank you
thank you
