We are adding a new bath to house with existing septic system. New bath is at lower elevation and will need to pump slightly higher to be able connect to existing drain (which goes to current septic tank). I checked with local plumber and he suggested another small septic tank and then use a pump to push to current drain. Quote is extremely expensive (30k) while we do all the trenching and digging. This is no go for me, since I am very handy and can do most plumbing myself, I am curious if I should go with another small septic tank or actually go with a self contained 40 gallon liberty sump pump system. This will be a full bath and will see regular use. Total distance from bath to tank location will be around 20 ft, distance from this tank to current drain is another 20 ft with total elevation gain of around 20 inches. Suggestions - Small septic tank and pump or liberty sump pump system?
