I have the channel body of a 56" linear drain installed at the curbless entrance of the shower. I have 4 showerheads (2gpm). Shower is 7' deep and 5' wide. 2" drain pipe.
With all 4 shower heads turned on everything drains properly. Have the Kerdi membrane in but not tiled so just experimenting to make sure it all works prior to tiling.
I can't test everything with the grate frame and grate in place prior to tiling, as the grate frame would block the drain. Is there any reason to think the addition of the grate will cause issues with drainage? My grate is a solid grate, so water flows into the drain at the edges. I could get a perforated grate but prefer the solid.
Will call Schluter but have a feeling they wont be super useful.
