Kam
I broke my plastic toilet flange when I was trying to get rid of a wobbly toilet. I got a metal flange repair kit that is basically a half ring with 2 screw holes and a slot for the closet bolt. The metal ring with the installed closet bolt slides under the plastic flange. However to get the metal flange in place, I had to cut a notch in the plastic flange with a hack saw blade. While cutting the notch I also happened to put a saw kerf that extends almost to the sewer opening on the plastic flange.
Will the wax ring work OK at sealing the saw kerf?
