flinx777
I’m setting up a full well water filtration system and would really appreciate a second set of eyes before I purchase everything. I've spoken with several local companies, and they quote extremely high prices for a proprietary all-in-one filtration system, pitching it to me even before they have seen my water report.
So, after researching this for some time, getting a full water test (see link below), and spending time figuring out what we need to filter out, here's what I came up with. I bought this property about 1.6 years ago and have never owned a well before, so there's a bit of a learning curve right now. It's a lot of money to invest, and before I buy everything, I want to make sure I'm setting this up correctly.
Well → Pressure Tank →
Spin-down sediment filter →
Big Blue 5-micron sediment filter →
Katalox Light backwashing filter (iron/manganese) →
Catalytic carbon backwashing filter →
UV disinfection (VIQUA VH410) →
Distribution to the main house.
Branch A (irrigation):
Water test highlights:
- Hardness: ~34 GPG (very hard)
- Iron: present
- Manganese: ~0.08 mg/L
- Arsenic: present
- Sodium: ~143 mg/L
- TDS: ~1000 mg/L
Property setup:
- The well and pressure tank are in a well house (downhill)
- The main house is uphill
- Garden irrigation is near the main house
- I have a barn downstream (at the top of the hill above the well house) that is part of this setup. I plan on adding a softener to the barn later (still confirming plumbing layout)
Proposed system layout
WELL HOUSE (primary filtration)
Flow order (planned):Well → Pressure Tank →
Equipment in the well house:
- Spin-down sediment filter (100 mesh, reusable)
- Big Blue 4.5” x 20” housing (5 micron cartridge)
- Katalox Light system (12x52 tank, ~1.5 cu ft, Clack WS1)
- Catalytic carbon system (12x52 tank, backwashing, Clack WS1) ... we're adding this as there is a farm operation about a mile from us, and the creek that feeds our well passes through their area.
- UV system (VIQUA VH410) ... while no biological concerns were noted in the report, we have a shallow well and wanted to avoid any future problems by adding this to the filtration system.
MAIN HOUSE SETUP
Incoming line → main shutoff → tee split:Branch A (irrigation):
- Water to go to this branch BEFORE the softener
- Supplies garden and future water storage
- No softened water (avoid sodium in soil)
- Water softener (~64k grain, Clack WS1, 2.0 cu ft resin)
- Then distributed through the house
- Under-sink RO for drinking water
Goals:
- Remove sediment and particulates
- Remove iron and manganese
- Reduce arsenic and organics (carbon stage)
- Disinfect water (UV)
- Protect plumbing (softener)
- Keep irrigation water unsoftened
Questions:
- Does this overall system design and order look correct?
- Any concerns with placing catalytic carbon after Katalox Light?
- Is UV placement at the very end (well house) appropriate?
- Do you see any issues with the flow rate (~12.5 GPM) for proper backwashing?
- Is splitting irrigation before the softener the right approach?
- Would you change anything before I purchase?
