I am very early in the process of building a new home. The builder's preferred plumber sub uses CPVC. I'm fine with that, provided it's adequately sized. This evening I checked on some other building sites in progress that serve as examples of what I can expect on my project.
For a house with 35-40 WSFU's, the plumber is using 3/4" CTS CPVC as the main trunk from the 1" water supply / 3/4" water meter. That seemed small, but what really caught my eye was the plumber's use of long, branching runs of 1/2" CTS CPVC.
For example, a single hot/cold pair of 1/2" CPVC lines on the second floor supplies the laundry room plus a bathroom with 2 lavs, a toilet, and a tub/shower. Furthermore, this 1/2" CPVC branch off from the 3/4" CPVC line happens in the basement, so the overall length of the 1/2" CPVC line must be 30+ feet. There are other examples of sizing that I question, such as a hot/cold pair of long 1/2" CPVC lines run from the basement and expected to supply two shower valves that would be operated simultaneously (i.e. a rain + body) plus two lavs and a toilet. All this is allowed by my city's plumbing code that stipulates minimum 1/2" line size for these fixtures, though the code does not address the fact that 1/2" CTS CPVC is roughly equivalent to 3/8" Type M copper.
Based on what I've read on the forum here and elsewhere on the internet, I believe this approach is very inadequate. However, I'm not a plumber myself and I don't want to go off half-cocked with the builder/plumber.
Can I get a sanity check? If I am in fact correct in my belief that this is inadequate, what should I be pushing for in my house with 39 WSFU? E.g. should I ask for 1" CPVC main distribution, with 3/4" CPVC branches to each bathroom, skip it all and go with 3/4" & 1/2" type M copper, or something else?
