Charlie Bosco
Active Member
So now that I finally have my water under control (High H2S) Its perfect coming out of my treatment. Katalox to Carbon to water Softener to house. My test ports confirm perfect water coming after carbon filter.
The pipes were so polluted for years before we moved in. Even with the clean water for the past 6-7 months.. the cold water pipes that get used the least build up a light smell when turned after sitting for a day.. If I run them with the aerator removed for 5 minutes of full blast.. they run clean smelling for a while. This I am certain is from the sulfur buildup in the pipes still leaching out..
I want to shock my plumbing with chlorine pellets.. The same pellets I use occasionally in the KL filter. My plan is as follows..
Fill the empty filter housing in my Signature Photo with the Chlorine tabs.
Set the KL, Carbon and Water Softener to Bypass.
Run all the faucets till I smell chlorine and then let them sit for a half hour to an hour.
Set the KL and Carbon back to Service and clear the lines until no more Chlorine smell and lastly set the Water Softener back to service.
