I am in the process of converting a laundry room to a half bathroom. The house is on slab, so I have decided to go with a Saniflo unit as I don't want to break into the slab. Specifically the Sanicompact (which is there all in one macerator unit), since the room I'm converting is also kind of small.
Since this is a laundry room, I do have access to a 2" drain pipe, which I plan to tie into. I had a few questions on the rough in for the Saniflo unit for anyone who may be familiar.
1) Standard ABS / PVC DWV systems are rated for 5 psi. Given that the Saniflo has a pump, is it acceptable/safe to connect at grade to the drain pipe without a vertical lift (which would dissipate some of the output pressure). (Such as the drawing A below. Or is it recommended to have some vertical lift (such as drawing B) and if so, what would this minimum lift be. Looking at the output specs of the Sanicompact, it's rated for a vertical lift of 9 ft, which converting to psi puts it right around 5psi for a 9ft high water column, so I'm thinking it should be safe to use this without a vertical lift. Is this correct?
2) When connecting into a vertical drain pipe servicing multiple fixtures (such as wash basin + saniflo), is it recommended to have the saniflo connect above (drawing C) or below (drawing D) the wash-basin (I plan to directly connect the wash basin to my drain stack and not use the wash-basin port on the sanicompact). I'm worried about the saniflo pump shooting waste into the washbasin horizontal run in C, so am thinking D would be better (although I'd be using a sweep tee to make the saniflo connection, so it's unlikely that the flow should enter into the horizontal run for the basin with C, but since it involves poop pumped around with pressure, better to be safe than sorry).
