Help me out
Wanting to add a half bath on a slab without cutting concrete. Planning to use saniflo access 3 macerating toilet/pump. The discharge line from the saniflo is 3/4 in and it says to tie it into the the main or a stack but didn’t specify minimum size that I can find. The stack on this side of the house appears to be 2 inches and the only other thing draining into it is a washing machine drain. Since it is coming out of a 3/4 in pipe, is this 2 in stack sufficient for the connection?
If this works do you drain the saniflo into the stack above or below where the washing machine tied in?
