Sandpoint well problems
Pot8ohead
Ontario, Canada
Hi all,
Posting this on behalf of my brother, who's experiencing serious problems with his sandpoint well.
This past January, he ran out of water & thought that perhaps frost had been driven into the ground and caused his pipe to freeze. He tried pumping hot water into the pipe, hoping to melt any ice build-up, but that didn't work. Occasionally, as the weather warmed, he'd try again to get the pump to draw water, but never did have any luck.
He eventually decided to wait until now (yesterday, to be precise) to put in a new sandpoint, since the quality of water from the old wasn't that great anyway and because he thought the problem might be that his old well had possibly just run dry (the water table has been a lot lower where he lives these past few years).
After witching for water, driving 14' of pipe into the ground (the old well was only 13' in), hooking up all the necessary components for a new well head and splicing into the old 1 1/4" pipe that leads to the pump, he's having the exact same problem as before.
We know there's water down there, but it's just not being drawn up and he can't figure out what the problem is. When he primes the pump, he can only pour approximately 1/2 a gallon of water in before it starts coming back up the prime hole (not sure what that's called). Before connecting the new well head to the old line leading to the pump, he poured water in from the pump end and it came out the other end, so we know there's no obstruction, but since there's roughly 46' of pipe between the pump and the new well head, it seems like he should be able to pour much more than 1/2 a gallon in before having it come back up through that hole.
The majority of the pipe running between the pump and where it was spliced into a new section leading to the well head is above ground, so we can tell that there are no leaks.
Shortly after the pump stopped drawing water and before thinking the pipe had frozen somewhere, he thought the issue may have been with the pump itself, so he replaced it with a brand new one (1/3hp jet pump). He also replaced all fittings between the pump and the line.
Does anyone know what the problem might be? Any help would be greatly appreciated.
Pot8ohead
Ontario, Canada
Just an update to this problem.
My brother took the pump in to have it checked, in case he damaged it over the winter as he attempted over & over to get water running. The pump is in fine condition.
Today he replaced the 40+ feet of pipe leading from the pump to the new well head in the hopes that that was where the problem was, but he's still unable to draw water.
Any suggestions?
Pot8ohead
Ontario, Canada
Sounds like your well is just not making any water. Try pouring water down the sand point. If water doesn't go down freely, it won't come up freely.
Thanks for the response.
I'll tell him to give that a shot & see what happens. If that's the case - and knowing there is water down there, is it possible that we simply need to drive more pipe into the ground to properly get at the water?
Kdinob
St. Simons Island, GA
Just a guess, but you mentioned that you "spliced" into line from existing well to pump. Could it be that pump is still drawing off old dry well? Have you tried taking the old well out of equation entirely?
Pot8ohead
Ontario, Canada
No chance that it's trying to draw from the old well; the pipe in question ran directly from the pump to the old well (which he doesn't know the exact location of; the well was put in before he bought the house).
Masterpumpman
Virginia Beach, VA
www.dci-inc.us
There's either a suction leak or the well isn't supplying water. NOTE: There can be water in the well but it may not be producing water!
As ValveMan said "Sounds like your well is just not making any water. Try pouring water down the sand point. If water doesn't go down freely, it won't come up freely".
