Pete147
Hi all,
This is my first post and want to say that this forum has been tremendously useful. I built a new house and moved in last October and had a well drilled. The well is 300 feet deep, my submersible pump is 120 feet up from the bottom and the well produces a healthy 15 gpm. The issue is that I have hard water and noticed sand and large sediment particles. The budget was tight so unfortunately had to wait on getting a water softener and filtration system.
Fast forward to March (5 months after moving in) and the water pressure in my faucets diminished considerably. So I removed all aerators and sure enough had plenty of sediment in them. I then purchased a Fleck water softener and had it installed last month. I also purchased a Big Blue triple filtration system (20" x 4.5" filters - one of them being a 10 micron pleated sediment filter). Even after installing the filtration system over a month ago, I still see sand and sediment in the bath tub and in the aerators of the faucets - although not quite as much as before but it's still there. I called the company where I purchased the filtration system from and they said there was no way that large sand particles and sediment were getting through three of the filters.
I also ended up buying a Lakos Sandmaster and installed it between the well pump and the water expansion tank. A few days later, I still have some sand in the tub.
I called the well company who drilled my well and explained the situation and they said there is no way that sand and sediment is still getting through the sand separator and triple filtration system. Their conclusion is that my pipes likely still have some sediment in them. I figured after a month of use that they would've cleared themselves out but maybe that isn't the case.
So my question to the experts is - what do you think is going on? Is it likely residual sand and sediment that is trapped in the pipes that I'm seeing? How do I get rid of it? I've heard of back flushing and also flushing out the pipes with compressed air but admittedly know very little about this and how effective it is.
Please help. I keep spending money on this situation and I'm still not completely satisfied with the results. I've attached a couple pictures of my water system, a plugged aerator with large sediment and the bottom of the tub from last week. Thank you.
