Good day all, longtime listener, first time caller.
I live in north central Florida and I have been wanting to wash down my own shallow well for some time to use as irrigation (and also in case of emergency during severe weather for toilet flushing, etc.). Anyway, I've read a number of threads here on the forum, as well as read everything I could https://drillyourownwell.com/. Today I decided to give it a go, but decided to use a 1" "exploratory" pipe just to see if I could figure out where the water table is and if this would even work or be worth the effort. Hooked up my drill head, got up on the bed of my truck, flipped the hoses on and man that 10ft stick of 1" PVC tore into the ground like a hot knife through butter. At about 5 feet the color of sand boiling up around the base of the pipe changed color dramatically, and at 6 feet, the "well" started drinking all the water I could pump at it (must have been 15gpm+ with the two hoses.) I continued working it into the ground, eventually getting another ~3 feet in before I just couldn't get it to budge any further down. After doing this for roughly 25 minutes I cut the water off and took off the drill head and got a tape measure just to see what I had. From surface to bottom is just over 9 feet and I hit water at exactly 6 feet. An hour later when I measured again the level was 6 feet 2 inches before hitting water.
I guess I have 2 questions for the honorable experts here:
1. Based on what I've read and seen, it would appear that I have indeed hit water at 6 feet. However my mind is having a hard time believing that there is actually water that shallow. Is this fools gold?
2. I realize I'm going to have to get deeper when I put in my actual production well in order for this to be usable at all (3 feet of water isn't going to cut it) but is it possible to use this "wash down" method with hoses when the sand seems able to "drink" the water at a higher volume than I can push and thus no mud being pushed up to the surface?
