We had a well drilled 3 months ago and all worked well for 2 months then sand started appearing in the water.
The well is shallow. 45 feet deep with the last 32 feet going into fine sand. It has good flow of 15gpm with very little drawdown.
They installed a 15 ft stainless steel wire wrapped screen 10 1/1000. The pump sits 3 feet above the screen and the staic water level is 10.
Talked to the driller and they are going to come back and redevelop the well with air lifting. I assume that will remove all the fine sand from the well.
My question is...is the 10 1/1000 well screen the proper screen for very fine sand? If the well is redeveloped and just fills with sand over time then it's a bandaid solution.
Anyone have any thoughts/confirmations/solutions. I'm not a well expert so my assumption about the incorrect screen may be incorrect
