Finished installing a 64k Fleck 5600 Econominder. After reading the install instructions, I set the dial with water hardness (20) and people (6); however, the salt setting label on the cover mentions that it is set at 18lbs. I read a couple of posts and used Gary's calculator to locate the proper salt setting--i think it's approximately 18 lbs. The seller of the equipment mentioned that the salt dial is 3x, so 6x3=18. Is that correct or should I set the dial at 18?
Thanks,
David
Thanks,
David
