Matthew Pacheco
I have the main venting ABS pipe coming from the roof. Vertically down into my basement floor. Now there is a capped off vent I'd say about 2 feet off the floor maximum, between the walls you can say. Then goes down into my floor with a 4inch toilet hooked up to that same drain and a 1 1/2 inch ABS pipe for the bath tub hooked up to the same pipe with a Y. That is all that is connected. I intend to install a kitchen sink on the other side of the wall hooked up to this same vertical pipe. Will this work? I'm new to this whole thing but do not have a problem doing any of it. Just need to do it correct. Here is an image hopefully that makes sense.
